Short Version.
2000 Dodge Grand Caravan, I two weeks ago I replaced the front brakes (rotors, calipers, and pads both sides) I drove the van 100 miles Saturday night with no problems. Sunday afternoon, whilst driving home from a resturant with 5 people in the van (driving super gingerly because they were my inlaws) the right front brake stuck on and smoked on the drive home. The calipers are new, and I have not had any other problems since I replaced the brakes that were trashed when I got it.
Long version
So heres the deal, I am the proud owner of a 2000 Dodge Grand Caravan, its got about 140,000 miles on it, its a little rusty, but I got it for free. A family member was getting rid of it, as it was 11 years old, and they wanted something newer, and it needed brakes and a few other things. They were going to donate it, but it sat all winter waiting for the donation company to pick it up. Being a consummate grease monkey elite shade tree mechanic tinkerer type, and being in the new family, new house cash flow situation, I swooped in and towed it home in hopes that I could make a decent enough ride that I could fit two adults, a carseat and a dog into.
Now when I got the van I knew it had some problems. Thats the reason it was free. But it is/was all fixable stuff. Typical of age and mileage It had a whiny power steering pump, it needed an oil change, the power steering lines leaked, the transmission cooler lines needed to be replaced. It needed a serpentine belt. It has a motor mount that needs replacing. The front suspension clunked because of worn out swaybar bushings and end link Its a bunch of work and few weekends and a few hundred in parts, but when the van was free, and you do the work yourself it costs a lot less. And try touching any used rig that is big enough for a growing faimly, and is new enough that the bank will give you a loan for less then about $15,000. (Cash for clunkers, worst idea ever, sincerely me)
The front brakes were completely trashed when I got the van, that is one of the reasons that the previous owner had parked it. And it was obvious that the right front caliper had seized, I could not push the piston back in. And that was the one that seized on, and had the most damages so I replaced it, along with the left front, as it was also the original one, and well they were both the same age, and once you have the stuff to bleed the brakes out, and have found a helper, you might as well.
So what causes disk brake calipers to randomly stick on when they are used gently? Because when I drive it angry, such as now, they seem fine.
Confused in Raynham,
