too much play in the steering
Twenty years old, something is worn out. Get it inspected.
Take a look behind the engine at the inner tie rods on rack and pinion, the inner tie rod bushings are a common failure.
Check and see if the rack and pinion assembly is securely bolted the frame of car.
