how do you put a power steering belt on a 1997 nissan pickup 2.4 liter motor.
Check with www.autozone.com. Create a login, and look up the repair guides. Drive belts are typically standard to replace, either serpentine with a spring loaded tensioner, or a v-belt with a screw tensioner and an adjuster bolt.
Autozone.com doesn’t have the instructions for your truck. If you don’t know how to perform maintenance, why don’t you get the repair manual? An experienced mechanic could do this task without a repair manual; but, there are a lot of other tasks where even an experienced mechanic must refer to a repair manual.
