2 - 3 - 4 - 5 Puzzler - alternate answer
In last week’s show it was said that the answer given (4-3+5^2=26) was the only possible answer. I came up with (3/2+5)x4=26. Am I math illiterate or are there two answers?
- Jeff
Cant someone find the time to post the question not just the answer?
You found another. Oldschool, the question was to arrange the numbers 2,3,4,and 5 so that the answer is 26.
There are many correct answers, not just one. For example:
26 = 5^2 + 4 - 3 << per tom and ray
26 = (3/2 + 5)*4 << per W Jeff S
26 = 24 + 5 - 3 << assuming “24” is an allowed use of “2” and "4"
26 = 25 + 4 - 3 << same issue
26 = 4! + 2
<< assuming “not using each number more than once”
<< allows one or more of the digits to be omitted
26 = 4! + 5 - (3 2)
The 4! is 4 factorial.
The (3 2) is the binomial coefficient (n m) with n=3 and m=2.
I suspect there are other solutions as well.
Here are a few more solutions:
det |4 -2| = 26
|3 5|
det | 5 3| = 26
|-2 4|
<< The determinant of each 2x2 matrix is equal to 26.
<< The matrix members can be re-arranged several ways
<< with the determinant = 26.
Re{(5 - 3i)(4 + 2i)} = 26
Re{(4 - 2i)
(5 + 3i)} = 26
<< This is similar to the matrix determinant.
<< The real and imaginary values of the two complex numbers
<< can be re-arranged several ways with the real part
<< of the complex product = 26.
and along the lines of the determinant solutions, there is the 2-D vector inner product (5,2)*(4,3) and its permutations.
If you can omit a number, then 3! + 4*5 works.
i got some more too, and they use up all the numbers and don’t create numbers by putting one in the tens place and another in the ones place:
Simple:
(4/2)^5-3!
3!*5-sqrt(2^4)
3!*5-sqrt(4^2)
3!5-2sqrt(4)
Involving the binomial coefficient or choose function
5*4+(3 choose 2)!
Involving binomial coefficent and modular arithmetic (n mod k)= the remainder when n is divided by k
4! + sqrt(2*(5 mod 3))
4! + sqrt(2^(5 mod 3))
I love the one below with complex arithemtic, but that requires introducing i, which is not an operation and so I think doesn’t count!
3!5-2sqrt(4)
uses two * operations. I made this same mistake several times.
e.g. 5!/4 - 3! + 2 = 26, but this uses two factorial operations.
I know that using i may be questionable. My argument for using i is that it is no different from using + or - to locate a real number on the real number line. Complex numbers are typically represented as points in an x-y coordinate system. The +i and -i designation for the imaginary part shows where the y-component is located in the complex plane, and the + and - designation for the real part shows where the x-component is located in the complex plane.
It’s interesting to see all these alternates. As I say above, I suspect there are many more.
Here are some others…
In examples 2-4, the last term is the absolute value of the square root of 4.
If X > or = 0, then |X| = X
If X < 0, then |X| = -X
I re-read the question, and only example 4 meets the criteria.
