The check engine light came on 2 days ago. The code PO 325 knock sensor #1, bank 1 came up. WHERE is this located and do I need a special socket to change it? Thanks.
The upper and lower intake manifolds must be remove to access the knock sensors. Inspect the wiring harness for rodent damage.
Thank You.
