Please help if you can… I have a 1999 Honda Accord that keeps turning off while I’m driving it. It has been doing it for a couple months now. Sometimes, it shuts off when the car is idling or stopped at a traffic light. Other times, it turns off while driving at cruising speed. When it turns off, electrical devices still function, ie. power windows go up and down, radio works, lights work…
I’ve replaced a couple different parts to try and fix it, but no luck as of yet. So far, I’ve had the following parts replaced: the main relay; the ignition coil in the distributor; the module in distributor; and the air filter. I also had the spark plugs regapped, and I have tried driving with the gas cap loosened to see if there was a problem with a vacuum forming in the gas tank.
What do you guys think? I have a friend suggesting that it could be the idle control valve or the throttle positioning sensor. Could the computer be going out?
