1999 Ford Windstar ground wire
having problem with the ground wire no start no start no dash light I can play with the ground wire some time it will start and cut back off help,
Assuming you has cleaned the battery post and both ends of the battery cable then seems like the cable has deteriorated. Replace with a new cable.
