12.3 volt is too low. Some sort of problem w/the battery, alternator, or overnight drain current. First step is to charge the battery w/a battery charger overnight at the 2 amp rate, then see if it will crank the engine and start 'er up. If so, then measure the voltage at idle.
Related topics
| Engine will crank but won’t start unless you spray starter fluid or fuel in it | 37 | 33825 | January 14, 2020 | |
| Chevy S-10 6cyl Pickup Hard starting when warm | 13 | 27561 | January 7, 2020 | |
| Mystery hesitation | 14 | 1829 | January 2, 2011 | |
| Hoping it's not the fuel injectors on my S10 | 42 | 13465 | August 5, 2009 | |
| HELP! '88 Chevy S10 with problem starting | 2 | 492 | July 20, 2008 |
