I have a 1998 4WD 4 Runner. The right rear axle keeps leaking into the brake drum housing. I have already had the bearing replaced twice. I don’t think the axle is bent because there is no vibration. What else could it be? (The rear end fluid stinks when it gets hot and the brake pads wear out quicker)
Related topics
| 1997 4Runner - Bent Axle? | 1 | 575 | February 3, 2009 | |
| 1996 Toyota 4Runner - Vibrations and a leaking rear end | 12 | 1481 | August 15, 2020 | |
| Slight oozing of brake fluid from the back of the rear Drums | 33 | 8540 | November 9, 2023 | |
| Brake problem with my 1997 Toyota 4 Runner | 4 | 1940 | July 23, 2012 | |
| Rear axle seal keeps leaking | 3 | 667 | December 25, 2007 |
