4 wheel drive would not engage replaced encoder motor,then vehicle stuck itself in 4 wheel drive was told by dealer that the transfer case control module needed to be replaced,so we had it replaced did not solve problem. the vehicle 4 wheel drive system is locked in and will not come out of 4 wheel drive,we can lock and unlock by applying ground and power at encoder motor circuit,but as soon as vehicle slips on snow or ice it locks back into 4 wheel drive and will not come out of 4 wheel drive.dealer now saying transfer case clutch assembly may be a problem need to disasemble the transfer case and inspect, is this a tough job and how long does it take to open transfer case and inspect,also what else could cause the 4 wheel drive system to stick in 4 wheel drive like this?
Related topics
| Repairing a 4 wheel drive that's not engaging | 7 | 34003 | June 5, 2018 | |
| Olds Bravada AWD failure | 4 | 6979 | November 24, 2010 | |
| 94 Ranger emergency brake & 4WD question | 8 | 1265 | April 28, 2014 | |
| Four wheel drive | 1 | 400 | December 14, 2009 | |
| Problems with 4 wheel drive | 1 | 368 | June 27, 2009 |
