ASD Fuse keeps blowing. I unplug PCM and fuse no longer blows. I plugged in pin 41-80 and the the fuse is still ok. Car just quit running and starter will not turn. Does pin 1-40 control starter and fuel??
Could I have a bad PCM??
Plug in the connector for pins 1-40. If the fuse blows, the PCM is shot.
Thank you
