1998 Cadillac Eldorado - Can't live without a jump
Have to constantly have it jumped. Might run all week just fine then sometimes every other day.Small
battery back jumps it just fine and ur goes right to 14 volts or 13.9 right away
Cadillac Eldorado Common Parasitic Draw - YouTube
The BEST Way TO Perform a Parasitic Draw Test - YouTube
How old is the battery? My first thought is you need a new 12V battery.
Have you checked the condition of those side post battery cable terminals for scale/corrosion and the junction terminal cable end? If not, that should be the next step considering the side post track record.
new battery new alternator post are new and clean, instrumental cluster replaced
