i get two codes both p0325
Code P0325 indicates a problem with the knock sensor circuit. But that shouldn’t effect the engine at speed.
Sometimes a crankshaft position sensor in the early stages of failure will cause the engine to stall at speed and then the engine runs fine. And a failing crankshaft sensor won’t always set a code.
Also, fuel pump could be getting weak.
I have owned the car for about three years. it does it about once a year. I have just been cleaning the MAF and it runs fine for about a year. I really dont know where to start. Thanks for your suggestions
Are you using a oiled performance filter? If so, that could be why the maf is getting dirty.
