1997 chevy silverado
i have a 1997 chevy silverado that the passenger side turn signal light just blew the brake light works but the turn signals dont so how would i go about replacing it?
In that model, the brake and blinker are the same bulb/filament. Does it just come on solid and stay there, or maybe blink very slowly? Check the front. Most likely, the front bulb is blown.
the rear bulb is blown i know that for sure the front one works but blinks very fast the only one that dont work is the rear passenger do i just have to replace the bulb ?
Should just be the bulb. The tabs are at different heights to make sure you don’t put it in backwards.
Good luck,
Chase
