My air conditioner only works at high fan speed for about 30 minutes, then I can use the other fan speeds.
Welcome, your Ask Someone has been redirected to Car Talk…
What do you mean your A/C only works on high fan speed, does any air come out at other speeds but just not cold, or Zero air comes out of the vents???
If you have air coming out of the vents but not cold then you probably need to take the vehicle into auto repair shop that does A/C work, NOT Jiffy Lube or someplace like that, but a real repair shop…
How long have you had the vehicle and how many miles are on it??
If the OP is referring only to fan speed, and not to the temperature of the A/C’s output, then I think he should consider the likelihood that the blower motor’s resistor is failing. After 28 years, failure of that resistor wouldn’t be surprising.
Sounds serious. I think you should sell me ur car. I’ll make a generous offer.
There are two offered with asking prices at Hemmings.com. A 1991 for $75,000 and a 1994 for $122,000. I know you’re joking, but IMO it’s worth highlighting the popularity of these rare cars.
But those advertised cars don’t need a $50,000 fan resistor…
I’ve heard the NSX described as a reliable Ferrari.
I recall reading an anecdote about the first time that Honda’s CEO was shown the NSX, and he asked about the cost of certain engine components. When he was told how much the connecting rods (made from Titanium, I think…) cost, he almost had a coronary.
Was it always that way? Could just be a normal climate control function. Check the owners manual.
Sorry, I have ordered custom casket handles for it and expect to be buried with a smile on my face, behind the wheel.
It was actually Cavell in post 5 that suggested you sell him your car, not VDCdriver.
A C8 is cheaper and faster. And newer
Yeah, but I can drive around for 15 minutes and see 4+ different C8’s out driving around on any given day… Probably 10-15+ C8’s in my small area alone, but I have only seen a handful of NSX’s in my lifetime…
Plenty of cars are, not the reasons somebody would buy a '97 NSX.
Not after you buy the gold chain necklaces.
