1996 Toyota Corolla - engine oil grading
i want to know engine oil grading for toyota 2E carburated 1300cc .
The cheapest grade of oil of the correct viscosity specified in your owners manual would be fine for your car.
Agree! A 5W30 oil would do; just don’t buy any of these super thin oils like 0W20 because a car that age and vintage will then consume oil. And those expensive oils would be a waste of money.
The latest oil grade is SN Plus.
http://www.pqiamerica.com/apiserviceclass.htm
You really need to check the really cheap oils, they may not be up to the needs of your engine.
This isn’t a US car. Where are you? What does your oil cap say?
My oil cap only shows weight
not grade.
Otherwise known as the “710 cap”. :wink:
And I bet that oil ‘weight’ (5w-30, etc.) is what the OP is looking for.
