1996 Saturn SL1 (single)
Hi, I have a 1996 Saturn SL1(single). Everything works fine, except when the temperature is below freezing, the car starts then suddenly turns off. The only way the car will stay running is if I hit the gas for a minute or two. What’s up with that?
Will the fix be expensive?
How much will that cost?
Did you mean to post this as a reply to Testers answer here:
http://community.cartalk.com/posts/list/2119201.page
Stay in the thread - use the reply button.
