I own a 1996 Jeep Grand Cherokee Laredo V8, and there has been an ongoing problem with it stalling. The check engine light is on and it reads codes about idle control sensor and 02 sensor. I spent a lot of money having both replaced, along with an processor. I had to bring my Jeep to a dealership so they could “marry” the processor to the car. The check engine light went out for about a day, then once the computer reset, light went back on. The codes still read bad O2 and idle sensor despite them being replaced.
The problem is when the car starts cold I have to keep my foot on the gas for a couple minutes or it will stall out. Once it has warmed up the car runs good. I turned the idle pin on the front of the throttle body to try to keep from having to put my foot on the gas but it still stalls. It seems like it is working better in the cold weather. My mechanic says that I may have turned the idle too far trying to fix it and that is why it is stalling.
I just want my car to run without having to warm it up every time. It wastes time and a lot of gas. Could it be something other then what I’ve already replaced? I don’t want to keep replacing the same things and not have it fix the problem.
