1995 pontaic grand AM idle trouble
My car is idling high while driving and when coming to a stop. I do not have a rpm meter so i don’t know what my rpms are reading. What could be the problem?
You could have sticky idle air control valve.
You could have a sticking throttle plate or throttle linkage.
You could have a vacuum leak just about anyplace in the vacuum system.
You could have an issue with MAF and or MAP sensors.
I’m sure there’s more and others will add.
