1994 rodeo won’t run correctly
I have a 94 rodeo 3.2 manual trans. I’ve done everything an I’m at a end here I really hope someone can help me out . Here’s what I’ve done . New fuel pump, new fuel filter, new plugs, new coil packs, new ignition control module, new tps , new iac, new timing kit , new crank sensor , injectors are working . It will start up but puts an has no acceleration what so ever! If you spray it with starting fluid u can give it gas but it still misses an bogs down after done spraying . Any help would be greatly appreciated
Check the fuel pressure again.
Fuel pressure is at 51psi
25 year old truck with… xxxxxxxx miles? You don’t say.
Have you run a compression test on the engine?
