Cougar, Busted Knuckles –
You ask if I disconnected the wire harness to the amp, put the fuse back in and still had a 300mA load.
Yes, I did disconnect the wire harness, and no, I didn’t see the 300ma load. Apologies for not mentioning that, it is important. That means there’s something in the amp that’s not switching off when it should. I need to review Blackbird’s advice again.
PvtPublic –
You said “Just because there is a blue/white wire from the radio, does NOT mean it goes to a same colored wire in the trucks harness.” Can’t argue with that, except that every wire in the two Metra harnesses matched colors with the truck wiring. So if I’m looking for a truck wire that controls power to the amp, the odds are it’s blue/white. Especially when it’s now one of the only wires still unconnected.
And of course I read the manual the first time. Heck, the radio and amp work, don’t they?
Here’s the key point of the troubleshooting, I think:
With the large black connector pulled from the amp, the voltage at the yellow wire read 12VDC. I pulled the #16 fuse, and the voltage dropped to zero.
And when that fuse is pulled, the parasitic drain drops to (essentially) zero.
So that yellow wire, to my simple mind, is the key to fixing this. Kill the 12VDC from going to the amp, and there’s no more parasitic drain. I might have misread the wiring diagram in the radio’s owner’s guide, but there’s no doubt that yellow wire going to the amp is the cause and solution to the problem.
I appreciate all the interest and advice. If nothing else, I’ve learned that this forum is great. But the dash, not sure yet where, is starting to look better and better for a toggle switch.
