I have a 94 GMC Sierra 4.3 w/standard transmission. Engine inop ,(broken rod). I have another 4.3 from a 99 GMC Sierra including harness ,minus fuse box and computer. If I swap the intake and the distributor. Would this setup work ?
If you can swap all the OBDI components from the old engine over to the OBDII engine, it should.
