1992 mazda mx3
Does anyone know how to adjust the idle on a 1992 Mazda MX3?
Get the engine up to operating temperature. Next to the battery open the cover for the diagnostic box. Place a jumper wire between the #10 terminal and the ground terminal. Connect a tachometer to the IG(-) terminal. Start the engine and if the idle is out of spec turn the idle air adjust screw on the throttle body to set the proper idle speed.
