So.
I have a '91 ford Ranger, and I’m having a great time working on this pickup, using it for dirty jobs, that sort of thing. Fun truck to mess around with.
At least - until it sprang the sort of fuel leak that looks like buckets of gas being poured out of the underside of your car. Pulled off the bed, and found a dry-rotted filler hose; replaced. Replaced the bed, and discovered that the buckets turned into a firehose.
Grr.
Took off the bed again, and found a split fuel line - “no biggie,” I says to myself, “Self, you can fix this.” And so I do! Splice in a new fuel line, get everything in nicely… and, after having removed and replaced the fuel line harness from the vehicle, I realized I completely have no idea what part of the fuel pump connected to what part of the fuel system… I marked nothing.
Thinking I had it sorted out anyway? Plugged it all up, went to start the car and … nothing. In fact, i’d hooked the fuel lines /backward/.
So … that’s easy enough to turn around, and I do so (taking the time to clean everything up)… but, now, the truck won’t start. If I’m lucky, it turns over once, then sits there like a buzzing lump.
Here’s the thing: I know the truck has an iffy battery, so there’s that. But… should I be jumping this truck, or did I do damage somewhere in the engine? Did I vapor lock it? Would attempting to start it cause more damage than has already been done… or am I panicking over a dead battery?
Help, gurus! I don’t /think/ I’ve done anything horrible, but I’d like to avoid doing more stupid things than I have on this relatively simple repair.
