1990 Toyota Corolla - Engine and trans issue
When accelerating the vehicle starts to lose power and the transmission does not run back to let the vehicle go faster
Okay, I think you’re saying the engine loses power and the transmission doesn’t shift into a lower gear when you step on the gas. Is the check engine light on? How long since the transmission fluid was changed–or even checked for that matter?
