Have been to 2 shops without results- when I turn on the AC - the car loses all power (not just a little) - won’t go above 10 miles an hour - then the fuse will blow - did replace fuse - then tried again - just fine for 5 minutes - cold ac, etc. - then lost power and blew fuse- if you turn off ac and turn off and on 5 to 10 times - will go back to normal running so long as you don’t turn on the ac. Now after taking to last shop - the idle is surging - at a stop- the idle will rev and decline over and over again - can lift on foot pedal to stop, but will also do surging whenever the pressure to the foot pedal is released during driving - Please Help - any advice will be greatly appreciated.
Related topics
| Help! | 4 | 799 | May 15, 2012 | |
| 1997 Mazda MX-5 Miata heat and AC quit after working | 1 | 434 | October 11, 2019 | |
| Misfires and a/c causing loss of power when idle | 11 | 7221 | August 18, 2009 | |
| 92 Miata Idle Problem | 0 | 209 | August 13, 2008 | |
| Power loss | 4 | 942 | September 13, 2013 |
