1988 Jeep Cherokee help asap
I replaced my thermostat and seal and it is leaking from the bottom bolt why is that please help asap.
That bottom bolt threads into a water jacket in the engine. Remove the bolt and apply a thread sealer to the threads of the bolt and reinstall the bolt.
Did that and still leaks, not much, but it leaks. Anything else?
You could try plumbers tape…but I don’t know if it will put up with the heat of a motor, which is a fair bit higher than hot water.
Chase
Plumber’s tape is pure PTFE, and I’ve used PTFE successfully in 450F applications. It has a high coefficient of expansion, but won’t melt.
Good to know…thanks.
Did the thermostat say put in the recess in the housing? I’ll bet it slipped a little and the gasket now can’t seal properly.
aint leaking no more once i undone the bolt a little bit its crazy. but it look’s like it is leaking from the bolt.
