Other than the year that is.  When I am driving, and accelerating, my car has recently had the habit of slowing down.  It will feel as if I need to press down to keep speed, then go back to normal.  No engine noise.  Will usually drop 5-10 mph before going back to normal.
 So what is it?  Brakes?  Trans?  Expensive?
Does it run rough at the same time or just slow down? Fuel filter? That’s a cheap place to start.
Your year is good. It means that the oxygen sensor('s) is / are bad. These were engine candy in the eighties. The engine would chew it, then the flavor would run out when it was done. Used to cost $60 for one at the ford dealer. You may need the part number from the original at the dealer.
