1986 Airstream MH P-30 chassis
I’m having a problem with disappearing brake fluid…The MH will sit for 3-4 months and the brake fluid in the master cylinder will be bone dry, front and rear reservoirs. It will take near a half quart to refill… I don’t have a vacuum booster ,the master cylinder bolts directly to the power steering pump…any suggestions??? There are no leaks or wet spots I’ve ever found… Thanks, Dragonmantwo
The wheels will have to be pulled and the cylinders and flex lines inspected for leaks. If the brake master and power steering pump are a combined unit, perhaps the brake fluid is finding its way into the power-steering system…But the fluid is going SOMEWHERE…
