The truck won’t start. I can turn the key and all the lights and console stuff turns on, but there is not even a click in the ignition.
I figure it is between the key and the ignitor module/coil. Any ideas?
Is your vehicle a manual or automatic? If it’s an automatic just put the transmission in neutral and try to start it. If it starts replace the neutral safety switch. If you have a manual transmission then the switch is attached to the clutch. Have it checked by a good mechanic. It might be a good idea to clean the battery cables and battery terminals.
It’s a manual tranny. I can push start it and it runs great. I’ll look into the switch at he clutch level, and let you know how it works.
