I need to start my truck after it has been sitting for a year and a half. Any suggestions other than priming the carb. that insures it will go smoothly. I don’t plan on driving it but need to get it out of the carport to wash it and send it to a garage.
Thanks
I would squirt some light oil in the spark plug holes and turn it over while the plugs are out.
If you used gas stabilizer you should be good to go. I world also change the oil due to the time that has elapsed.
If you mean that you are going to have it taken to the garage by a tow service just let them winch it out of the carport .
Thank you for your response. It is filthy dirty, I have to wash it before it is picked as the cats have sprayed it and dirt and dust etc.
Thank you for your response. Knowing me I would cross the wires, lol. The oil was changed as they were trying to fix it and it hasn’t been run since.
Thanks again. I just hope the little pocket charger will work, it is supposed to?
