The Vehicle:
1968 Ford ‘Falcon’ Ranchero
351 Cleveland 4 bbl. (5.8L)
3 Speed Auto.
Engine Mileage: 0 [Just got it back from the machine shop]
The Problem:
The heater hoses- I need to know which one flows out from the engine/pump, and which one flows back into the engine/pump. On the 351C one hose is attached to the block- the other attaches to the pump. I would assume that the one on the pump is the one that flows out TO the heater core- is that correct?
Thank you.
Yes. The hose from the water pump supplies the heater core with coolant.
