09 tacoma will not restart after turning off
I have 2009 tacoma pickup w/10k After starting fine and driving a few mins. and turning off it will not restart for aleast 10=15 mins. All the instr. lights come on like normal…but it will not crank nothing? no starter noise …nothing I contacted my dealer The service guy said (never heard that before) ANY THOUGHTS?
It sounds as if it is heat related, maybe a camshaft position sensor. Have you had it scanned for codes?
If it has an automatic transmission, the next time it won’t start place the transmission in neutral and then try starting the engine. If the engine starts there’s a problem with the park/neutral safety switch.
+1 for @Tester. BTW…find another “service guy”…this problem is as common as dirt.
