Car won’t start, spraying starter fluid in and will run but when stop spraying it shuts off, red lighting bolt light on, check engine light, ideas on what it could be?
Get the codes read and it’ll provide an idea.
can’t bring car anywhere…won’t run
See if your local Wally World sells one of these.
That’s why they invented towing companies.
The lightning bolt symbol indicates a problem with the electronic throttle control system. Could be a dirty or bad throttle body, or perhaps something wrong with the accelerator pedal sensors.
If I said you need a new fuel pump, what would you do?
