Sometimes the locks in the doors do not lock or unlock and I have to use a key or do it manually if its not the drivers door. Only in a certain range of temperatures does this problem occur. It happens when it is roughly between 65 and 85 degrees out.
It will not have this issue when it is cold nor will it happen when it is beastly hot, just when its a bit warm. I press the lock button on the fob and all but the drivers door or the door right behind it will lock. It is frustrating and I want to know if there is something I can do to help prevent this from persisting and to know if the locks will eventually fail completely if it goes unchecked.
it has never been in an accident, but shes had her doors slammed a few times in the past by my passengers.
