07 Lexus RX350 Lower Control Arms
Hi
I need to replace both lower control arms for my 2007 Lexus RX350 built in Japan.
I went to lexussouthatlantaparts.com, and it says:
OEM $181 * 2 = $362 + shipping: PRETTY EXPENSIVE !!!
part #: Right 480680E010; Left 480690E010
Japan product part:
http://www.lexussouthatlantaparts.com/showAssembly.aspx?ukey_assembly=763000&ukey_make=1082&ukey_model=15677&modelYear=2007&ukey_driveLine=8074&ukey_trimLevel=19114&searchString=control%20arm
North America product part:
http://www.lexussouthatlantaparts.com/showAssembly.aspx?ukey_assembly=757773&ukey_make=1082&ukey_model=15677&modelYear=2007&ukey_driveLine=8074&ukey_trimLevel=19114&searchString=control%20arm
The part numbers are the same for Japan and N. America trucks,
so does that mean I don’t need to worry about which one won’t fit if I choose from the list at rockauto.com?
http://www.rockauto.com/en/catalog/lexus,2007,rx350,3.5l+v6,1433555,suspension,control+arm,10401
I heard that the ones with heart marks are popular.
Should I choose one of those? Does anyone know which one is as good as OEM?
Please help…
I’d go with the “Hello Kitty” marked ones.
What’s wrong with them? Bushings? Ball joint?
bushings are bad and no shops near me have tools to replace only bushings.
The ones with a heart mean that customers that have provided feedback have liked them. You can take that for what its worth.
Why do you think the bushings are bad. Most of the time there is nothing wrong with 10 year old bushings. They just develop some “checking” around the edges, but the bushings themselves are perfectly fine.
I’d go with the rockauto parts that fit your model, about $50 each. No reason to spend that crazy money for the first ones you listed.
They are torn and clunking when I hit the brakes.
Clunking when hitting the brakes can definitely be caused by worn control arm bushings. Are you sure the problem is confined to the lower arms only? Often the upper arms will display the same problem when the lower arm bushings start to fail. There’s two control arms required b/c the control arms hold the wheel in the correct (mathematical) plane, so the wheel is aligned properly. Like if you cross two sticks, that defines the orientation of a plane (flat surface), right? One stick doesn’t. So it doesn’t make much sense to fix the lower arm, but not the upper. Makes sure your shops inspects the upper arm bushings too. Otherwise the work needed to replace the lower arms may have to be redone.
re: OEM vs aftermarket. You can often get the OEM version of a part from rockauto too. Look through the list there on their website, see if some of the parts they offer have an “OEM” in the description. Maybe you can find an OEM version that is priced right. I’d be inclined to use the OEM part if I had that problem myself.
GeorgeSanJose
Thanks for your input.
Click the lexussouthatlantaparts.com link, you’ll see there is no upper arms, so I’m pretty sure.
I called rockauto once and asked the guy answering the phone and he said the ones with a heart are the more “popular” ones. I crosschecked some of the parts with reviews on amazon or model specific cars and it was a bit all over the place.
galant
Thanks!!
I think I’d go with Moog.
I replaced the lower control arms on a 2005 Lexus is300 for the same reason. It seems like this is a problem that happens with aging Toyotas and Lexus. It’s a pretty challenging job without a lift, but I did it on jack stands and it worked out OK. One thing I know about this type of job - often Toyota uses the exact same part, and charges a lot less for it. It may have the same part number, and when you buy a part from Lexus it may come with a label that says Toyota. It’s insulting and left me very annoyed, but at least I figured it out before they ripped me off.
Also, Hondas and many other cars that use those “rubber donut” front bushings that eventually tear at 100K miles or so.
A lot of shops don’t have the ability to replace just bushings…but they usually have access to a machine shop that does.
I replaced lower control arm bushings ONCE, never again. That was a lot of work. Even at $181 for new factory control arms, that is a bargain compared to the work involved in replacing the bushings.
I checked & you are right, no upper control arms on the rx350. The shock/strut ass’y must assist in the role of an upper control arm to reference the front wheel to the correct plane. There appears to be a stabilizer bar/link involved too. Good idea to check those bushings too during the control arm replacement.
