I can’t seem to pull sufficient outside air inside the car even when I set the auto temp to the outside air temp. Has anyone had this problem?
T
How do you know that outside air is not getting in? Is the volume significantly lower when you switch from inside to outside? In that case, the outside intake might just be plugged with leaves or something. Check it out.
