2002 dodge stratus R/T 3.0 v6 (AUTOMATIC) 105000 miles
I replaced dead battery and now the car stalls at low speeds ( under 15mph ) It starts every time but will not idle even in neutral.
HELP
try a new pcv valve
The idle air control valve (iac valve) may be disconnected or not working.
Check for vacuum leaks as well and clean the throttle body.
