I was wondering how much it would cost to replace the cam seal plug? It seems to leaking a little bit of oil. Car has 124k is this worth fixing? I have not had to add ant oil since last change 3k ago.Is this a costly repair or a simple one? Thanks Jack
If the oil is leaking on your timing belt or inside cover(by all means fix it).
If it is just leaking onto your engine slightly simply check your oil level every 2-3 fuel fillups and monitor the situation. In your shoes I would not fix the leak unless its damaging your car.
