I have a 2000 Toyota Camry that has a unique problem. The Check Engine light NEVER comes on even when first starting the car. I have access to a scanner and know that the car periodically throws a catalyst code but the light never comes on. I just assumed that the bulb was burned out.
Today while solving a non-working clock issue I had to take the instrument cluster to get to the clock. While I had it out I decided to check the Check Engine Light bulb. It looked fine so I took I replaced it with a bulb that I knew worked fine. Again, nothing. The bulb doesn't light at all. About 4 weeks ago my timing belt broke while driving (thank god for a non-interference motor) and it threw a code for the camshaft position sensor but again the light never came on.
Anyone have any idea as to why the light never comes on?
Comments
- Spam
- Abuse
- Troll
Off Topic Disagree 1 Agree 1 LikeYour light should come on according to the above link when you set the key to the II position, along with other dashboard lights, and be the one light remaining on after a few seconds. If the rest of the lights come on, but the CEL doesn't, and if you bought the car used, the plastic display cover might have been painted with black paint to hide the light, a sneaky old trick to sell a car with a problem. Otherwise, honestly, I have no idea. I'd suggest using the scan tool on as regular a basis as you can manage.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeAlthough here in Virginia we don't have emissions tests we do have a yearly inspection and an illuminated MIL is cause for failure. So I not that worried about it, but would like to figure it out. With access to the scanner I can clear it before the inspection.
Other than that issue the car runs great and still gets 34mpg on highway with 210,000 miles and the original clutch.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeTester
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
Off Topic Disagree 1 Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeThen check for continuity from the lamp socket to the computer connector.
Also one pin of the lamp socket goes to ground, check this continuity too.
If all that checks out then it's a problem in the computer module (lamp driver).
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeI have an '05 Camry that has a CEL that never shuts off. I can change the oil and a day or two later, it never fails to come right back on. A knod for consistency. I've had it for six years now without any other noteworthy issues. Dealers and others have shown me the key, switch, steering cloumn,... key, switch, steering column trick to shut it off, and, oh yes, that works,...for a little while. Maybe twenty four hours...a little tounge in cheek here please. But then it is right back on to keep me company again. It does shut off from time to time completely randomly (everybody's gotta eat I guess), but never for long.
I know this is the inverse of your problem but it is interesting to see the results of bigger companies relying on multiple vendors for the same component and it's sometimes many sub-components. Ya never know what ya gonna get. BTW, Click & Clack, my older brother and I were changing engines in my dad's side yard back in the early seventies in Burlington, MA. My dad however, grew up in Your Fair City, in East Cambridge on Spring St. back when men were men and cars needed constant attention.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeThat leads me to a question to Cougar, can you tell me more about fixing the lamp driver IC?
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeAs far as replacing the lamp driver in the ECU it is fairly simple thing to do if you can get the replacement part. You can locate it on the board by following the trace on the PC board that ties to the pin for the lamp. Hopefully something else is wrong with the circuit and it will be easier to fix. The ICs I replaced controlled more than one device so they had multiple outputs, four I think.
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeIf you check this wire with a volt meter or test light note that the ECU provides a ground to illuminate the light.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeKeith in the 3 years I have owned the car the light has never come on. I have had to clear a catalyst code on a few occassion. My guess is the O2 sensors have never been replaced. So the codes have been cleared probably 6 times. Most currently being 2 weekends go, and I checked it again this past weekend so there have been more that 3 cycles.
Nevada you make a good point. I will pull the cluster again and check for a cut there as well and also check at the connector at the ecu. If no cut wire, then I'll let go of the issue and move on. Again I enjoy the satisfaction of fixing something that I never worked on before.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
