I have a 2002 Passat that is only blowing cold air when it is supposed to be heat. I have checked the following items:
1. Both heater hoses are hot at the heater core which would indicate that the core is not restricted.
2. Air has been bled at the heater core and the antifreeze is at the correct level.
3. Car thermostat is operating correctly and maintains a steady 190 to 195 degrees.
4. When temperature control lever is moved from "cold" to "hot" the air noise definitely changes like a damper is moving but there is no change in
air temperature. This is a manual control with cables (not digital read-out).
From what I have read so far I am convinced that there is a problem with the blend door but referring you back to
#4 (air noise change) I believe that the cable is moving the damper. Can the blend door be accessed on this car without removing the center console? Can it be accessed through the glove box area?
Comments
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
