- Listen
- Our Show
- Car Info
- Buying
- Owner Reviews
- Tom and Ray's Reviews
- Research a Car
- Find a new or used car
- Cars We Hate the Most
- Secret Tricks of Car Salesmen
- Hybrid Vehicles
- Calculator
- New Car Incentives
- More…
- Owning
- Post a Review of Your Car
- Tom and Ray Explain Maintenance
- Check Safety Recalls
- Want To Do It Yourself?
- How To Keep Your Car Running Forever
- Premium vs. Regular
- Change a Flat
- Car Cleaning Tips from a Pro
- Official Car Talk Guide to Jump-Starting Your Car
- Guide to Better Fuel Economy
- More…
- Cars.com Content
- Mechanics Files
- Blogs
- Community
- Fun Stuff
- Store
- Contact
Comments
But if you insist, YES a 200 amp alternator, correctly installed, will cure your need for more power..But it's not that easy...Big alternators need multiple belt drives or at least a completely different belt arrangement..to carry the heavy load imposed by the oversized alternator..
Another solution is to power the amp from a 100 amp deep-cycle boat battery carried in the trunk...
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeEven if you don't play the music loudly, you still need lots of amps. Volts don't kill your system; it stays at 12 or so. Amps need big cables and power source.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeThe only thing I see as possibly wreaking havoc is that every time your bass hits, it imposes a severe demand on the car's electrical system, dropping operating voltage and causing power surges, which can eventually damage the car's electronics.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeUnless it's kept independent of the factory electrical system with the use of relays and so on I can see problems brewing with alternator plugs, fusible link ends, or any one of a number of other connections.
The son of a friend of mine got a job babysitting new oil wells some years back and he had a rig like what is mentioned. His dad got real tired of having to go out to some dark oil lease at night with jumper cables to bail the kid out when his boomin' amp ran the battery down PDQ.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeIf you are intent on blowing out your eardrums with a high powered system, I think that deep charge boat battery to power the system is the way to go. It would be completely independent of your car's electrical system.
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeFunny how perspectives change over time. The reason they went to higher voltage was to reduce the necessary wiring gauge and therefore reduce the cost. Power is power. If you need to supply 1200 watts, there are many ways to slice the egg. Do the math and you may discover the old wire gauge was insufficient for that amount of power even though they had a penchant for over-designing things back then.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree Likehttp://swap.qth.com/view_ad.php?counter=971233
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeIt's amps. Voltage remains at 12 VDC. And with any luck, yes, it will kill your electrical system. I'm certain your neighbors would agree with me.
Regarding the hearing loss comments, this is a real issue. I had a neighbor who blasted his music constantly, and both of his kids have serious hearing loss. I jave another friend, retired secret service, who will suffer serious hearing danage by spending too much time around Air Force One.
I strongly urge you to reconsider your "jammin'". Unless you want to spend your middle age with a hearing aid and your old age deaf.
- Spam
- Abuse
- Troll
