Okay, I've got some time on my hands today. Lake many, I've long wondered what it would be like to build my own car from scratch. I've often thought of ideas to include. I've included some below. What would yours include?
SUSPENSION/CHASSIS:
1) A-frames up & down, front & rear. The inner articulating joint of the A-frames would be as close to the center of the vehicle as possible. This should reduce the amount of camber necessary in order to maintain a cosistant tract as the wheel moves through its travel, thus keeping the tread as flat on the ground as possible.
2) Camber, caster, and toe in on both front and rear sdjustable "on the fly" via a plug-in control box. Perhaps by adding a VSS input a program could allow settings to be saved for various speeds and create automatic constant changes as the speed changes. This could probably be accomplished vis program-driven synchro motors with worm drives.
3) inboard brakes fromt & rear
4) lightweight wheels to keep unsprung weight to a minimum. Off-the-shelf to keep replacement costs to a minimum.
5) tire widths only as wide as necessary to reduce rolling resistance.
6) wheels placed as far out to the corners as possible.
DRIVETRAIN:
1) a midmounted horizontally opposed engine of reasonable economy. Mounted low, for a low Cg. Perhaps a Honda Goldwing engine would do the trick.
2) one of them newfangled auto/manual (optional) trannys.
BODY:
1) fiberglass body panels with the color in the panel.....like boat builders do.
2) door window frames that wrap up over the roof to a center rail and contain removable "smoked" roof panels.
3) Long, dihedral opening doors that, when combined with the over-the-roof window frames, create extreme ease of entry.
4) a vertical rear window, power opening. That, with the roof panels removed, should provide a convertable like experience.
5) a rear spoiler with good surface area that could rise to become an air brake when the brakes are applied. (stole that idea from McLaren). Perhaps it could be powered by scoops that open via solenoids to allow airflow into pneumatic actuators. That would eliminate the need for hydraulics, using wind pressure rather than loading the crank with a pump.
6) a front end designed purely for aerodynamics, panels providing downforce while at the same tike directing flow past the brake discs.
7) rearward-facing bullet-cameras at the crest of each front wheel arch and the center of the rear. Three (or four) small screens could project the images providing a panoramic view of whats beside and behind the car. Much more effective than mirrors.
8) large side scoops would feed the radiator etc.
9) the rear would be wide open with only horizontal slats, to allow air coming past the engine and through the scoops to exit without creating unnecessray drag or undercarriage pressure (lift).
INTERIOR:
1) simple and straightforward, with a flat dash with analog gages arranged simply and toggle switches to control functions (lights, wipers etc.)
2) regularly used functions (directionals, cruise, radio, etc.) on the steering wheel.
3) paddle shifters.
4) low, laid back seats, the most comfortable available.
5) tan leather
What would be your idea?
Comments
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeLower control arms pivot outboard enough to compensate for tire roll under, which would be out a bit because I would not want tires with a profile less than 60 and I would want a lot of roll resistance, big sway bars.
Regular doors that i can hold onto to help get in and out.
Chair height, up right seating and no thigh support, it cuts off the blood to my lower legs. I do want good lumbar support and maybe a tailbone cutout.
Solid roof, no sun/moon roofs or the like.
No spoilers, airdams or scoops, just good plain aerodynamics for fuel economy.
Mirrors large enough to do the job, square. About 3.5x5"
LED dashboard with selectable displays to suit my needs, but enough sensors in the engine that I can select a full analog or digital display of all critical information.
Tan leather would be nice.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeTailbone cutout sounds like a good idea.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeThat's pretty well what I have now, except for the backup camera. That one is on my Christmas list.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeInteresting Thread that's going to get many different type vehicles.
My current vehicle is a SUV. Because of our family needs an SUV fits nicely.
. I'd love to see a Diesel SUV about the size of my 4runner. 4-cylinder Turbo Diesel. From what I've read about them in Europe and South America they should have more then enough HP and Torque for my needs.
. Power Windows and door locks.
. Rear defrost with heated side mirrors.
. I prefer Cloth seats.
. Analog display. Get rid of the Tach. I'd prefer to see other useful gauges instead (oil pressure, oil temp, Tranny oil temp) just to name a few.
. No sun-roof.
. Rear Spoiler to keep the window clear in wet roads.
. HD Radio. I can't live with out one now.
. For and SUV I'd rather give up a little cargo space for more space in the rear seats.
. Rear window like I have on my 4runner. It operates like a side window. My pathfinder's rear window operated like a hatch.
. If I must settle on a gas SUV...I want one with a fuel filter I can replace without dropping the gas tank.
. A NON-Interference engine with a timing chain. Again probably not a problem if Diesel.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeI actually am pretty satisfied with a lot of the designs at this point. Some of my criteria was a little hard to find though. I want a long long warranty-10 year, 100K bumper to bumper. 4 wheel disc brakes are mandatory. Front wheel drive. Comfortable interior with guages and easy to understand info centers and audio. Good styling, but fold down seats to be able to carry a 2x4 or so in the trunk. At least able to tow a couple thousand pounds, and of course reasonable gas mileage (30).
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like18 MPG or better overall
Good front seats
Rear wheel drive or AWD with a rear bias
Good sound system
dual mode exahust like on the newer corvettes and Boss Mustangs
4 pot brakes up front , 2 pots in the rear (or better)
fully defeatable traction/stability control
power windows/locks/seat
full instrumentation
a hood with gas struts rather a prop rod
timing chain
remote start
manual transmission
limited slip diff
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeAnd I liked the cathedral like head room and the uncompromised structural rigidity so no sunroof for me. In fact give me the fold flat seat arrangement of the Honda Fit. Continuously variable seat adjustments would be nice but not critical. Speaking of the fit, I felt a little unprotected without side airbag.
Give me electric power steering with fast ratio and it should shut down completely at high speed. Why would anyone want to be able to steer with one finger and not know exactly what their tires are up to while their lives are depended on them at 70 mph? I want disc brakes with no dead travel in the pedal.
Power everything except seats would be nice. But I don't need auto climate control. I want to adjust my temp just by groping the knobs instead of looking at them while moving. I liked the instrument panel in the middle, as it opened up space for wallet, phone, gps, etc. Instantaneous mileage read out would be nice.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeI NEED power lumbar support and climate control. They are absolute necessities.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Likehttp://en.wikipedia.org/wiki/File:1-achsiger_Traktor.jpg
They may be coming to a dealer near you soon.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeAnd if you were to build your own car, Rod, what features would it have?
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeMy perfect car...hmmm...let me think about that...
Well, first of all, it would have to be designed for very easy servicing.
It would also have to be big enough to accomodate 5 passengers in comfort, with abundant legroom and headroom, and a floor without a "step-down"-- but not so long that it is a pain to do parallel parking.
Most likely a wheelbase of ~113 inches, with an overall length of ~194 inches, and a width of ~70 inches would provide that combination of generous interior room, coupled with a relatively compact exterior.
It would have to have power that is more than just adequate, coupled with class-leading fuel economy.
Most likely, an engine of ~4.5-5 liters would provide that good balance between power and economy.
It would have to have a logically laid-out instument panel, equipped with easy-to-read gauges and no idiot lights.
And, of course, it would need oversized disc brakes.
Oh my God!
I just described a 1964 Studebaker Lark Cruiser sedan!
Yup, all you would need to do is to adapt the engine to fuel injection and computerized engine controls, fit it to a modern 5 or 6-speed automatic transmission, and make it compliant with modern safety regs, and you would have a sedan that would still look contemporary, and would rival the less-expensive Mercedes sedans in terms of performance, albeit for...many thousands of $$ less.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeWell, since Studebaker stopped producing cars in 1966, I suppose that their designs have little in common with current cars!
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
