Join the Car Talk Community!
Discussion Rules
Sign In Register
Road Noise
edited October 2011 in Repair and Maintenance
How do I reduce road noise in my Toyota Rav4? Would it help to undercoat it like they do up north? I thought about thicker carpet. it drives you crazy on a long trip.
«1
Comments
  • edited October 2011
    One of the regulars on these boards actually reported on his own sound deadening project about this a while back. The thread he posted about that (click) should be helpful.
  • Don't rule out a mechanical problem with the vehicle. If you are noticing an irritating level of road noise, you may have a tire, wheel bearing, or suspension problem. Wheel bearings are especially notorious for this, starting out subtle and gradually creeping up in volume till it sounds like you are driving on rumble strips all the time. I just replaced a bad wheel bearing in my 17 year old minivan, which had a really annoying amount of cabin noise at speeds above 20 mph due to the bad wheel bearing. Now it's quiet as a tomb until wind noise starts creeping in around 75 mph. Unless you know the vehicle has been this way since new, there may be a mechanical problem causing your intolerable road noise, and this is a certainty if the car didn't used to be this way and suddenly is. I suggest taking the car to a trusted repair shop to rule out a tire, wheel bearing, or chassis problem before gutting the interior and adding more insulation to try to cover up what may be a symptom of a dangerous problem. A good mechanic will know if this level of noise is normal or if a mechanical problem is causing the noise.
  • Cig, you've flattered me by remembering, and I thank you.
    I don't personally recommend using undercoating, because although rubberized undercoating does make a marginally good sound deadener it can also clog drain and venting orafices and create corrosion opportunities by doing so.And it does nothing for reflected sounds in body cavities, it solely (and marginally) changes the resonent properties of the sheetmetal by chaning its mass. And if undercoatng is applied in wet weather it can even trap moisture in cavities wher you don;t want it.
  • Like Mark, I too had a problem with road noise. It was a constant drone at highway speeds. A new set of tires did not help but later replacing the bad wheel bearing put an end to the noise. Have it checked out.
  • I used some Second Skin in the back of my Matrix and it really made a difference.
    Other places I'm going to try it is in some window air conditioners and a washing machine.
  • Careful tire selection can help considerably.
    How old or new is your RAV4. Also how old are the tires and do you perform regular rotations on them?
  • Hmmm....structural damping on appliances? What a great idea! Mine are in the basement, but the idea is a good one.
  • So circuit smith where would one purchase second skin? is it hard to apply?
    thanks for all the help everyone!
  • mountain bike if I am unable to take the panels out have no idea how to do this or what they are can I just put the second skin all over the inside flooring and cover with a higher grade carpet?
  • Andrew It is brand new!
