- Listen
- Our Show
- Car Info
- Buying
- Owner Reviews
- Tom and Ray's Reviews
- Research a Car
- Find a new or used car
- Cars We Hate the Most
- Secret Tricks of Car Salesmen
- Hybrid Vehicles
- Calculator
- New Car Incentives
- More…
- Owning
- Post a Review of Your Car
- Tom and Ray Explain Maintenance
- Check Safety Recalls
- Want To Do It Yourself?
- How To Keep Your Car Running Forever
- Premium vs. Regular
- Change a Flat
- Car Cleaning Tips from a Pro
- Official Car Talk Guide to Jump-Starting Your Car
- Guide to Better Fuel Economy
- More…
- Cars.com Content
- Mechanics Files
- Blogs
- Community
- Fun Stuff
- Store
- Contact
Comments
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIf you have to replace it, I don't know the Vibe's setup - but one of the most common is that its just mounted with about 3 screws up in the dash behind/under the glove box. Sometimes you have to remove a trim panel.
Mostly it sounds like you want to drop $20 at an auto parts store for a repair manual. Autozone's website also has some basic, barebones repair info for most cars that is free.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeCheck the fuse, if its OK, then the resistor pack would be next. If the motor works on the highest setting, then the resistor pack is defective, if not, then it's the motor. The switch itself could be bad but that is unlikely.
The blower motor cannot be economically repaired. It is built in such a way that the brushes cannot be replaced. This seems to be the trend these days, make things that can't be repaired so you have to fork over $200+ for a motor instead of $6 for brushes.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Likekeith, I've purchased aftermarket blower motors for far less than $200 - about $60, actually. Although it might coast $200 it the brshes were made to be replaced.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeRockAuto has one for this vehicle for less than $50.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeRelays are used to switch power on to devices that require a fairly high amount of current. The blower motor uses perhaps around 8 to 12 amps. The relay is a fairly small device and if you do a web search on a Bosch relay you will be able to see what they generally look like. The blower relay should be located somewhere under the dash. They unplug from a socket so they are easy to replace. Once you find the relay try tapping on it to see if the blower will turn on. If it does then replace the relay, it has bad switch contacts inside it.
- Spam
- Abuse
- Troll
- Abuse
- Troll
