- Listen
- Our Show
- Car Info
- Buying
- Owner Reviews
- Tom and Ray's Reviews
- Research a Car
- Find a new or used car
- Cars We Hate the Most
- Secret Tricks of Car Salesmen
- Hybrid Vehicles
- Calculator
- New Car Incentives
- More…
- Owning
- Post a Review of Your Car
- Tom and Ray Explain Maintenance
- Check Safety Recalls
- Want To Do It Yourself?
- How To Keep Your Car Running Forever
- Premium vs. Regular
- Change a Flat
- Car Cleaning Tips from a Pro
- Official Car Talk Guide to Jump-Starting Your Car
- Guide to Better Fuel Economy
- More…
- Cars.com Content
- Mechanics Files
- Blogs
- Community
- Fun Stuff
- Store
- Contact
Comments
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeHow is the fluid level in the power steering reservoir? Have you had to add any fluid? Have the hoses been checked, especially the return hose? Even though the return hose isn't under much pressure, it is only held by circular clamps. They are more prone to leaking. A fitting on the high pressure side could be loose and drip fluid on the rack making it look like a leak.
Where are your state inspections done? at a state run inspection station or at garages that also do repairs? If the latter, then definitely go somewhere else. If the second opinion does not confirm a leaking rack, then report the inspection station to your state officials.
In some states, garages that do inspections are not allowed to do any repairs uncovered due to an inspection nor are they allowed to recommend another shop as this would be a conflict of interest. If this shop is pressuring you to have the repair done there or at another shop they recommend, then report them.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIt's really not feasible to replace seals in a leaking rack for several reasons. Generally speaking, you can't even buy the seals needed as they are simply not available.
Many of these seals are specialty hard seals that are very delicate and special tools are required for installing them. Finding the tools needed is often difficult if not impossible.
Add in dust boots and replacement of both inner tie rods which are more than likely worn and even if one had the tools and seals in hand it's just not cost effective to repair a rack; assuming it could even be repaired and the spool housing is not grooved up.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIf the dust boot on either end of the steering rack appear to be oily then the rack seals are leaking.
If you can't inspect this yourself then get another opinion on it at the least. Inspection should take no more than about 30 seconds.
- Spam
- Abuse
- Troll
