Join the Car Talk Community!
Discussion Rules
Sign In Register
Do I really need a sway bar
I have a 97 Ford Mustang GT. The rear sway bar broke. I was looking at getting a used sway bar but no local junk yards have any in stock for the GT model. Then I thought of just removing the sway bar until I come across a used one. What happens if I drive around without a sway bar. I'm basicaly commuting to work and back home? Don't plan to do any racing or crazy driving.
  • edited September 2009
    I don't have the technical expertise required to tell you about that (and have never driven w/out one), but you can probably find a boneyard replacement here:
    Years ago, both front and rear sway bars were optional extras. On my Dodge Dart GT I had to pay extra to get one, on my Caprice only the front one was standard; I paid $130 plus installation for the HD police package one, even though the car already had HD suspension.
    You can safely leave the rear sway bar off until you find a new one. Just don't drive the car to the limit on a twisty road, since it will behave differently.
    JC Whitney and other auto specialty houses must surely carry this item. Plan to pay $150 or so plus shipping.
    I can't add to the advice you've been given but since it's highly unusual for a sway bar to break, exactly where did it break?
    If an end link broke that's a simple matter of replacing the link kits; and inexpensive.
    It wasn't the link but the actual bar that broke. I also found this quite strange since its quite a thick piece of steel and I don't recall going over something recently that would cause that kind of damage. I can only suspect that it started as a crack and finaly gave in. Its a pretty clean cut across the bar maybe about eight inches from where it bolts into place on the passenger's side of the rear wheel.
    Wow ! - What WERE you doing ???? :)
    ~ the term "catastrophic material failure" springs to mind...
    Considering that this one broke the way it did, I would want a new one if it was my car, not a used one.
    We are talking about a Mustang GT, a car with a reputation for having all the power, but none of the handling of a high performance car. I think you need the sway bar. You never know when emergency maneuvers will be necessary because some kid runs out in front of your car or some driver fails to stop at a red light. This bar allows you to make emergency maneuvers without rolling the car over. If it is ever needed, you won't see it coming.
    Thanks for clarifying the part about the sway bar. Since the odds of a metallurgical fault are near zero, I'd have to think a bar breaking would be due to metal fatigue caused by an accident, someone jacking the car up with a jack pad on the bar, heavy use of an accelerator foot, etc.
    In all of my years, I've never seen or heard of a broken sway bar. The only damaged sway bars I've seen were bent ones due to accidents.
    Just a theory, but what if the vehicle suffered a rear end accident in the past and someone used a torch to straighten a tweaked sway bar out? The material used in sway bars does not take well to heat from a torch.
    What happens when you drive without one ?
    The handling is different, and until you notice the difference is not to your liking, you really dont 'need' one right away.
    However, you could wreck the car.
    Say whuh ?
    Yes. You have become accustomed, over years of driving this car, to the handling properties it had with the sway bar. You may not even know all it's doing for you nor under what driving situations it serves it's true function.
    You will become rudely surprized one day, without fore-warning, when driving in one of those situations and the car doesn't go where you tell it to.
    This instantaneous surprize lack of response is horribly dangerous. You'll have miliseconds to react and, depending on circumstances, could easily wreck it.
    The solution ?
    If you intend on leaving it off for a long while, Go out and practice some 'sway bar moves'( cornering, lane changes, both accelerating and braking ) with it to acclimate your sub-concious to the new properties of NO sway bar. ( a new Ford one is only $ 138.00 )
    It might very well be a metallurgical fault. 20 years ago, a microscopic flaw destroyed an airliner and took 110 lives (UA 232).
    I find it hard to believe that a Mustang with a relatively low center of gravity will tip over. However, it will cause the car to understeer more. You're less likely to spin out on the road, but you're more likely to run straight into what you're trying to avoid in an emergency
    As others have said, the sway bar serves to improve handling, and the car can be driven without it, but I highly recommend getting a new one as soon as you can.
    Sway bars do break from time to time. I have never had to do one on a Mustang, but a few years ago, I had a rash of them come into the shop, all front ones on Buick Regals and Pontiac Grand Prix's. The local GM dealerships couldn't keep them on the shelf for us! I must have done 5 or 6 of them in two months!
