Join the Car Talk Community!
Discussion Rules
Sign In Register
brakes hot
i have a 2006 chevy silverado after i drive a while both front brakes get to hot to touch but the rear brakes are fine. it dose not do it all the time.
  • edited September 2009
    It is perfectly normal for your brakes to be to hot to touch.
    I strongly recommend that you get this looked at. You may have dragging front calipers, and this could lead to overheating and brake failure. A tech can tell visually. Overheating will cause glazing and discoloration of the rotors, and often sticking causes uneven wear on the pads.
