This NY Times article is interesting. I was taught to set my mirrors as stated in the article at a corporate safe driving course. The method works. If everyone set their mirrors in the manner described it would save lives and reduce accidents. This is an attempt to spread the word. If you've never tried setting your mirrors in this way, please give it a try.
After adjusting your seat, move your head as close to the window glass on the driver's side as you can. Then set the mirror so you can see down the side of the car. Next, move your head as far to the passenger side as you can and set the right side mirror so you can see down the side of the car.
When a car coming up on you from the rear leaves the view of your rear view mirror, it will show up in your side mirror. When it leaves your side mirror the front of the car is right next to your driver's door window and you can see the car easily with your periferal vision. There is no longer a "blind spot".
http://whe...utomobiles
0 •
Comments
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI cringe when ever I see some one turn their head to back up but realize that when mirrors are in the safe driving position they may be useless for backing up on many cars. You can't be in a rush and should be taught to use your mirrors correctly, even if it means constantly adjusting them.
Good post UT. If it saves a life, you've done more than your share by reminding us.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeWhat a lot of people refer to as "blind spots" are not the areas you can't see with your mirrors. Blind spots are sometimes created by structural components, like the B pillars and C pillars, when you look over your shoulder. Even if you set your mirrors this way, blind spots are not a myth. They are still there. Even with your mirrors set this way, there are still areas around your car you can't see.
Dagosa, I cringe whenever someone doesn't turn their head to back up, especially in a car. Even truck drivers look over their shoulders when they can. That is why they almost always back up at an angle where they can look over their left shoulders. Straight line backing is easier, but you see less of your path, and blind side backing is next to impossible without getting out of the truck several times to check your path.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThe point I did not make well is that there is in some vehicles, a contradiction between ideal mirror adjustment for backing up and safe on road driving and mirrors are not a "set and forget" feature. Wear them out.....it's should not be unusual to have a finger on the power mirror control and constantly adjusting it while backing for an operator that has the feature.
I like the option of back up and perimeter driving cameras and feel that given today's technology and how inexpensive they can be, should be mandated for many vehicles. Sorry for the suggestion for you conservatives.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeSure you may have turned your head and eye-balled each mirror, but
..if you do that too fast you'll miss something anyway !
ssslllloooowwww down and you'll see everything.
Even with convex blind-spot mirrors, you'll miss the fact that something is there unless you take the extra second too assess what you're seeing there.
When training for my pilot's license they taught a method of searching the sky for others.
-- You can notice something moving....if you're not. --
ie; hold your gaze still for a bit , then you'll catch movement, even in your peripherals, that escape you if your eyes are moving too.
This works well with automotive mirrors as well. I back all three truck into my driveway so as I pull to the curb to prepare to swing out for backing in, I look into the yard area for two grandsons bolting about.
then swing the truck around and check the mirrors. Then ease back in reverse.
Keeping vision stationary for a second often reveals the movement I'm looking for.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeFisheye (convex) spot mirrors are simply the best solution. I never leavr home without them.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThen, I can lean a little - left or right - to see the side of the car.
- Spam
- Abuse
- Troll
