I am thinking that the big black plastic cover on the engine magnifies the sound.
And when you take that cover off…?
Everything is SO covered up that I can’t tell about the injection. And I don’t know how to take the cover off the engine. The noise does seem to be the valves
This Tigershark engine has something called “Multi-Air” which controls the air intake and valve timing. I am pretty sure that the sound is coming from the intake. I guess I will check with the dealer to see if it is normal or if something is not quite right.
Thank you all for your comments.
